Mixing CV with alcohol based mohawk dye stain
3/12/15
Is there any reason why you can't/shouldn't mix the two?
Conversion Varnish and dye in the same batch? I used a vinyl sealer and was going shade on that, then put top coat of CV, but is there any reason why I shouldn't mix dye with top coat as we typically do with pre-cats
Thx!
3/12/15       #2: Mixing CV with alcohol based mohawk ...
shenendoah
yes you can, though you might be better advised to use acetone based microton or metallics. Acetone base dyes will allow one to blend into urethanes, polyesters, etc. - even shellac while the microton and metallics are more light fast/stable. Urethanes are moisture sensitive so the alcohol based dyes - microton/metallic or not, should not be should used. Cv's no worries.
