Hindered Amine light stabilizer, where to find.
3/23/15
Russell Scherer
Hi all, I read a thread on the use of "HALS" to keep the natural tone of the wood species you are using the same as hot off the planer without being affected by light. I would like to know if anyone has a source for small shop volume. Thank you.
3/24/15       #2: Hindered Amine light stabilizer, wh ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
Tinuvin 292: A liquid hindered amine light stabilizer especially developed for coatings.
Kremer Pigments sells it
3/25/15       #3: Hindered Amine light stabilizer, wh ...
Russell Scherer
Thank you for the info. On the source for the HALS. I was told that it can be reduced in a solvent or water. Do you use it as a pre treatment or dissolve it in your finish? I will be using GF exterior 450 clear satin. I reached out to the GF people and they tell me that they incorporate HALS in the finish. But they won't say how much. I want to be sure I keep the material from darkening as much as possible. Thanks again for the input.
