A trick with steel wool you would never think of
4/3/15
There was water damage to the top of a buffet that left black marks amd big rings in the veneer that didnt sand out 100-150
So a guy i work with, had me sand it as consistent as possible, stain the piece, wipe off the stain, then he took 0000 steel wool and started rubbing at the black area and removed the black. We use aniline dyes, so we can shade whatever may be needed, but it took out the black.
Then, where there were some cross grain scratches, you re wet the area with stain right away, take 150 grit paper (other than cheap 3m and sand out the bad areas, then re stain. You're effectivly wet sanding with stain.
You learn something every day
4/3/15       #2: A trick with steel wool you would n ...
ThomasFR
First thing to try when addressing black rings & such is oxalic acid. 1 or 2 applications followed by household bleach after drying, followed by clean water rinse. 90 to 95% effective with no abrasion or material loss. ps Virtually no real bleaching of the wood will result.
4/14/15       #3: A trick with steel wool you would n ...
Gene Wengert-WoodDoc
I also suggest oxalis acid, which is a safe acid and is sometimes called wood bleach. It is safer than chlorine bleach. It does instantly remove iron stains. It does need to be rinsed off afterwards.
