Spraying line
4/5/15
astrit Member
Dear Sir.
We are interesting to invest in spraying line. We already have offer for Giardina complete line:
INFEED BELT
CLEANER G08/09
FILLER APLICATION ROLLER G84/20
UV LAMPS GST 1400
SPRAYING ROBOT DUALTECH 4/01
MICROWAVE DRYING TUNEL MOS/8
EVAPORATION HOT AIR TUNEL GP-JET/6
UV LAMPS GST 1400/2
OUYFEED ROLLER
Do any of you have experience with such brand Giardina finishing line, if would be possible to use water and lacquering base and how much times need for changing the colors because we need to work with different customers which request a small quantity..
4/6/15       #2: Spraying line ...
chris
i would contact The American wood finishing institute for advice. AWFI.org
AWFI
4/6/15       #3: Spraying line ...
herb johnson
no need for paying a consultant like awfi
go right to the mfg, they can give you all the information you need
the other people seem to have allegencies to particular vendors, just my two cents
you can get seperate fluid circuits for different coatings, i am not sure what you call a small run but an automated line isn't for short runs, maybe run them thru an off line booth.
if you have dual fluid circuits, you can run as a waterborne and one as a solvent, i would not comingle the two.
i would guess you could flush out one circuit in under five minutes unless you are going from black to white etc
igiardinna is a good line
good luck
herb j
4/10/15       #4: Spraying line ...
JeffA
You must not be very interested in getting an answer as I PM you and you have not responded.
4/10/15       #5: Spraying line ...
titi Member
Dear Mr. Johnson thank you very much for information
