regulator for compressed air for turbine hose
4/13/15
Dan Cook
I have an hvlp turbine system and used to have a regulator that worked off shop air that I could use in the shop when I didn't want to use the turbine (noise). The regulator went bad and I can't find another one. Does anyone know of a source for one? Thanks!
4/14/15       #2: regulator for compressed air for tu ...
chris
call finish systems.
Finish Systems
4/14/15       #3: regulator for compressed air for tu ...
Dan Cook
I called them but they didn't have anything like that.
4/16/15       #4: regulator for compressed air for tu ...
Jim Conklin  Member
Website: http://www.jhconklin.net
If I could find it, I would send it to you. I had one that went with an Accuspray 10 gun. It looked kind of like this:
Is This It?
4/16/15       #5: regulator for compressed air for tu ...
Dan cook
That is the right idea except that is designed to go on the gun which makes the gun quite bulky since the hose is already much larger. The one I had was wall mounted but the same principal. It converts regular compressor air to more like the air from the turbine at around 10-12. By being on the wall it doesn't add bulk to the gun and hose.
