glaze with glaze on top, side of extra glaze?
4/13/15
Kyle
I have an issue, job was glazed by 2 different finishers, & certainly looks like it...
schedule is as follows:
poplar, light to med distress, finish sanded to 180 Abranet
-SW Kemvar surfacer
-SW Kemvar plus
-SW Vinyl sealer (50% reduction)
SW glaze
-vinyl sealer
(here's where I'm at tonight)
then 2 topcoats water white CV..
I would like to glaze again, then seal once more, in order to straighten this order out.
then the 2 topcoats as usual
glaze is fairly light, but all parts front & back are fully finished, so lots of expense for extra steps, but wayyy more if it becomes a redo.
can I add another application of glaze / sealer to my sandwich?
or better of scrubbing everything down?
(or would that potentially turn into an even bigger sack of gremlins??
4/14/15       #2: glaze with glaze on top, side of ex ...
Leo G
All depends on the dry mil thickness you have on the doors now. Not sure what the dry mil limit of your finish is but it's likely 5 mil.
So you need to figure out what you have on there in order to see if you can add more.
