Airless shop setups that don't cost a fortune?
5/11/15
Jim Miers
Wondering if any of you have seen any more affordable airless turbine setups that don't cost a fortune? We typically shoot around 4 different colors on any day, and possibly pre-cat lacquer as well. It's not that I am avoiding a compressed air rig but it is nice to not hear the compressor all the time in a small 3 man shop. From what I have seen there are some nice airless HVLP setups but each subsequent gun is very expensive, often times several times the cost of a mid-range HVLP. Any suggestions would be helpful. The ultimate would be a gun system that we could use the 3M disposable cups with. Thanks.
5/15/15       #3: Airless shop setups that don't cost ...
chris
I would buy an air compressor as having compressed air has many advantages in a shop. if you dont need air you can always turn it off
gives you way more flexibility plus you can get a gravity HVLP very cheap.
5/16/15       #4: Airless shop setups that don't cost ...
Shane
Well said..... you could always buy a nice compressor that will have plenty of volume to run good spray guns and air sanders.... money spent here would be better than the airless rig in your small shop... heck you could even stud out a small room , sound prood insulation and ventilate it so it doesn't get to hot in there...
