prep for lacquer
5/21/15
reid Member
I am going to finish a piece of Redwood burl with Target coating Lacquer. What grit sandpaper should I use to prep. Also if you have any tips please let me know
5/23/15       #2: prep for lacquer ...
Tim Member
Pretty sure that is spelled out on the can or the Target PDF download.
Anyway, 220 should be enough.
They say with waterborne finishes that you sand and then pre-mist the piece with water to raise the grain, sand, and then go ahead with your finish schedule. what I have found works for me is 1 or 2 coats of Zinsser sealcoat before the finish So, when you flatten any raised grain, it stays flattened so I;m not doing 8 coats. I also like to mix a tiny amount of a purplish color into the shellac to help nullify the yellowing of the shellac.
