Kremlin excite
5/24/15
I have a brand new Kremlin excite gun that I have not used in about a month and I went to use today to use a pre-cat sealer and my fan pattern is only about 5 inches when the adjustment knob is all the way out. I thoroughly clean it after each use and I went to use today to use a pre-cat sealer and my fan pattern is only about 5 inches when the adjustment knob is all the way out. I clean it with pure SW Acetone and made sure that the little holes are all cleaned with the micro clean needles I have. for whatever reason it still wont give me a wider than 5 inch fan pattern. do any of you have any suggestions as to why this may be? I took off the orifice behind the air cap That has the 16 or so holes in circular fashion and saw it had gunk. Cleaned it, put it back together and no difference
Any thoughts?
5/24/15       #2: Kremlin excite ...
Brian T
Check your seals. You may be missing the one in your air cap or it may be torn.
5/24/15       #3: Kremlin excite ...
Heres my gun. Was there a seal at the end?
5/24/15       #4: Kremlin excite ...
It use to be snug to take off the air cap and now its easy to take off
5/24/15       #5: Kremlin excite ...
Dave
you are missing the seal on the gun in the first photo.
5/24/15       #6: Kremlin excite ...
Dave,
I cant find a part num. will u pls help me? And where can i buy it right away? Amazon maybe? Links pls
5/24/15       #7: Kremlin excite ...
Dave,
As silly as it seams, missing that one seal can mess with my fan pattern?
5/25/15       #8: Kremlin excite ...
I think i found it but this one place wants like 73.00 for a pack of seals. Crazy!!
View higher quality, full size image (640 X 1136)
5/25/15       #10: Kremlin excite ...
Alan
I personally do not like the excite gun specifically for this reason. The o ring on the end constantly falls off. This will most definitely make the fan pattern smaller. I keep a whole bag or two of them around because they always fall off.
5/25/15       #11: Kremlin excite ...
Robert Member
If its brand new, why not contact the outfit you purchased it from and ask for one. Should have been a complete ready to use out of the box item. Looks like its not.
5/26/15       #12: Kremlin excite ...
Dave Edgerton  Member
Mike, its dave who commented on the missing seal. Ya you have to buy a set of 10 seals. everything for a kremlin costs 100 bucks. You have to go to the kremlin website for the codes. The fan pattern will not change at all. that is based on what tip you are using. It is stamped into the back of the tip like 09-092. YOu really need that seal the gun will not work right without it.
Kremlin Distributors
5/26/15       #13: Kremlin excite ...
I just saw in the pic you have an 09-094 tip which will give you about 8" wide at 10" distance from a surface. Acetone does not cut it for cleaning the tips. you either have to have an ultrasonic cleaner or use gun wash. You dont have to open the fan adjustment valve that much. Max 1/2 turn from closed is all you ever want to open it.
5/26/15       #14: Kremlin excite ...
herb johnson
you need a 150 040 329 pack of seals
without those you cannot redirect the atomizing air to the horns of the air cap
it they get damaged or cracked, you will have the same problem
also check the fan pattern controller to see if it is bent
and yes, get your credit card out to pay for them
good luck
herb j
5/26/15       #15: Kremlin excite ...
Mike Member
Lol. Thx Herb! What a joke! I bought them this morning. I bought the EOS 15-1 from my Sherwin Willams and called them this morning and the way even more than the place in PA.
5/26/15       #16: Kremlin excite ...
herb johnson
suprising, how much of a difference in price?
figured sw would be the same price as everyone else
5/26/15       #17: Kremlin excite ...
Mike Member
Like 20-25.00 before shipping cheaper. Through that place in PA, it's a flat rate of 10.00, until u hit 100.00, then its free. SW doesn't offer that kind of deal
