New to dye/stain Spraying
6/7/15
Sean Member
Hello I am having trouble with my kitchen cabinets. I decided to go with a undercoat of rub on stain then spraying it with a toner mixture. The mixture is 20 ounce lacquer thinner, 4 ounce shellac, and about 1 tablespoon of dye. I know i must be messing up somewhere because i cant get the spray to get into the detail corners of the cabinets doors. Do i just hit them with a brush a couple times then spray? or am i not fogging it enough?
On a side note i do want to use pre-catilized lacquer for my finish. Should i switch that out instead of shellac?
p.s. i can't find pre-catilized lacquers in home depot where else sells the stuff?
6/7/15       #2: New to dye/stain Spraying ...
Go to Sherwin Williams and stop mixing up your own concoctions. Pre Cat lacquer is not a great kitchen cabinet finish. It doesn't hold up near the stove, dishwasher, or sink. I know, my personal kitchen has shown a lot of troubles in those areas. It's 25 years old now, but showed trouble before it was 10 years old. It's also very critical what film thickness you spray and how much build. It's okay for shelving, or book cases, not kitchen or bathrooms. Use conversion varnish. You should include a picture of what you have now, wood species, a picture of what you want to achieve, what stain you used, etc... for more help here. I sure hope you aren't practicing on your completed doors, because then you get to strip them too.
6/8/15       #3: New to dye/stain Spraying ...
Kevin
your not getting into the corners BECAUSE your "fogging it on". Corners are going to have a blow back effect and are pretty tricky to master. Your going to want a diluted form of your toner so you can lower air pressure and get in that corner with a nice wet pass. If your spraying with to much air pressure, the air just bounces out of the corner along with your toner.
