Alcohol dyes on top of Cv?
6/16/15
Is it going to be ok if I put alcohol dyes over a clear top coat of conversion varnish? I know you can put it on top of sealer, but what if the top coat has already been applied? If it is ok, will i be ok mixing it with another top coat, since I need to catalyze it?
6/17/15       #2: Alcohol dyes on top of Cv? ...
jimmy cream
if I was going to attempt to color shift CV , I would use a toner and then another coat of CV.....providing of course the additional coat wasnt causing an over-mil . I find this easier than adding color to top-coats .....better control ( for me anyway )and it provides for a clear coat over the last color step .
I would never apply an alcohol dye directly to anything other than raw wood . it contains no binder ......the alcohol will evaporate , leaving nothing to stick the dye particulates to the coat underneath .
6/22/15       #4: Alcohol dyes on top of Cv? ...
Sean Jackson Member
I do some intercoat staining btwn CV coats, you've gotta be sure and quick though, spraying on is a must, as is wiping off cleanly and evenly. It does give great colour depth/intensity in a stronger way than toning the clear coats. Make sure your CV has had at least overnight to harden or it can stick when you wipe the spray stain off and your not in a good place then! Not standard practice but it works if handled correctly.
6/22/15       #5: Alcohol dyes on top of Cv? ...
Denny J
I have done a lot of cabinet repair and if I want to shift the color I have found that using a WB stain that is thinned can adjust the color of cabinets consistently. When it dries I shoot a few coats of WB clear over it. Prior to staining I will scuff with a sanding sponge to give both the stain and clear something to bite into.
