Tip for clawlock and resistant
6/19/15
Barry
I have a 7 year old Kremlin 10:1 pump. I spray clawlock and Campbell resistant. Am wondering
what the experts recommend for a tip.
Is there a substitute for Campbell resistant that is less prone to spray problems. I`ve heard nightmares
about the customer that didn`t like the color. The shop then had to respray and the finish cracked.
And I had problems with bubbles in the finish the first time I sprayed. It required two
additional chemicals added to the finish. This retarded the finish and allowed the newly sprayed
surface to dry slower not trapping bubbles in the top coat.
6/19/15       #2: Tip for clawlock and resistant ...
JM
What I would recommend is switching to Valspar, Chemcraft, Sherwin, or Acroma. The best thing about MLC finishes is their marketing.
We used to spray MLC stuff exclusively and had all sorts of various problems. Switched to Valspar and Acroma and all problems went away.
6/21/15       #3: Tip for clawlock and resistant ...
Leo G
Replace Resistant with Stealth. Use 10% Reducer and 15% Flow Enhancer #2.
Use either a 06 or an 09 tip.
06 tip fluid is 35 psi air is 16 trigger pulled
09 tip fluid is 40 psi air is 19 trigger pulled
Plus or Minus of course.
