MLC color variances
6/23/15
Dan/drbwoodworks
We had a color consistency problem with mlc magnamax over two coats of claw lock. It was a small job , we used one gallon . Face frames and doors look different , as in two different colors . Everything was top coated at the same time always being agitated . Seems like we always have problems with MLC , it's the easiest product to obtain where we are .
6/24/15       #2: MLC color variances ...
Leo G
Claw lock is a primer. It does not need to be color consistent and you shouldn't assume that it will be.
Did you box the gallons so that you have everything mixed into one uniform color?
Thickness of the primer will also cause color differences.
This is not a problem with the material.
Even if you are spraying with pigmented finishes you are suppose to mix all the cans together to get one uniform color.
6/25/15       #3: MLC color variances ...
Bill Miers
I'm with Leo, primer shouldn't matter. You should be able to shoot a door that was primed grey and one that was primed white and with sufficient coverage and coats achieve the same color in the end. Chat with your local dealer, it's usually the best place to start.
6/25/15       #4: MLC color variances ...
Mastercabman
I think the OP is talking about the magnamax not the claw lock
But I do not have any idea why he's having a problem
I use MLC and I never had any issues
6/25/15       #5: MLC color variances ...
Leo G
If he's talking about Magnamax pigmented then he shouldn't be having that issue. I thought he was spraying clear over primer. Works good for black, ok for white.
6/25/15       #6: MLC color variances ...
Mastercabman
Maybe he is using clear over primer?
Then again wouldn't he seen the difference before top coating?
I think we need more info from the OP so that we can better understand
Pictures can also help
6/29/15       #7: MLC color variances ...
Dan/drbwoodworks
Sorry , I wasn't very clear . Pigmented magnamax over claw lock . Only 1 gallon of finish was needed.
Well it turns out when we delivered to the client , we did not see any color variances. So it must be the lighting in the shop .
6/29/15       #8: MLC color variances ...
Mastercabman
Ah yes the lighting!
I have installed jobs where the crown moulding look totally different color
Turn out to be daylight reflecting on walls with off white/light tan in color
Can be very tricky!
Glad it turn out OK for you
