refinishing Kitchen cabinets
6/24/15
Michele K  Member
Website: ferniewoodfinishing.ca
I've had several recent requests from customers about refinishing their kitchen cabinetry. They are looking at alternatives for reviving the look of their kitchens without the cost of replacing the cabinetry. In all cases they are considering a solid color finish over top of an existing stain and lacquer. Most of these kitchens are face-frame type cabinetry which would require a fair amount of on-site spraying or painting.
I'd like to spray a solid color lacquer or CV for ease of spraying and good looks and durability, but am wary of how the years of built up grime and cleaner residue might affect the topcoat.
I plan to do a thorough sand and de-greasing with xylene or naphtha.
Any tips or cautions from someone out there who has more experience with this than I do?
I've finished plenty of new build kitchens but as yet have only repainted one kitchen using a latex sealer and paint. It was a cheap & cheerful touch-up for a house that was going on the market. I was not completely happy with how it turned out.
Any recommendations for a lacquer or CV finish?
6/24/15       #2: refinishing Kitchen cabinets ...
Bill in Oregon
If you don't get a good answer here, you might consider going to the painttalk forum and asking the same questions.
6/24/15       #3: refinishing Kitchen cabinets ...
Denny J
It's no problem but IMHO it is better to use a WB pigmented finish than to use a solvent based finish. I have done this sort of thing since the 90's and with the proper steps it is a great solution. It works on furniture as well.
6/24/15       #4: refinishing Kitchen cabinets ...
Leo G
Standard practice to use an isolation barrier.
Shellac or Vinyl Sealer.
6/24/15       #5: refinishing Kitchen cabinets ...
Man, I avoid refinishing at all costs. I'd only do it to keep the doors open, and even then would have to think it over. Just as you mention, CONTAMINATION! Then besides that, the customer is pinching pennies but will expect the very best. Good luck if you get the job, but I expect you'll be on here in the near future talking about adhesion issues.
6/25/15       #6: refinishing Kitchen cabinets ...
nick
I'm with Denny, I do this 4/5 times a year and I go WB as well. I've been using this finish schedule the last few years with 100% customer satisfaction and 0 callbacks;
clean with dirtex (ammonia cleaner) spray on, wet sand with a maroon scotch-brite, wipe dry
mask as needed
apply one coat pigmented shellac
prep as needed
apply two coats wb pigmented lacquer
apply 1-2 coats of clear wb urethane
I've been using Target and it works great but I'll bet there are more than a few other options out there.
Of course i take the doors and drawer fronts to the shop and spray what can't be moved on-site. For on-site spraying I have a 4stage turbine.
be forewarned; removing and marking doors and drawers then taking them to the shop and then bringing them back and re-installing them takes time also masking takes time
bid accordingly
