Translucent Nitrocellulose Lacquer/Help Me!
6/29/15
Kurt Robert Moss Member
I am trying to finish a Fender Telecaster with a Butterscotch Blonde Nitro Lacquer. This beautiful translucent finish evolved with white tint aging. The photo I'm sharing is an opaque finish. It's my favorite shade. There is no definitive shade. The colors pre mixed and sold by several vendors/Luthiers look terrible. Please can anyone suggest a product line? The guitar body is ash. The neck is maple. The neck should be a translucent amber. Thank You, Kurt Moss
Guitar Reranch Gallery photo 1952 Tele
6/30/15       #2: Translucent Nitrocellulose Lacquer/ ...
Shane
Kurt.... Use a nitrocellulose of your choice and use Mohawk dye stains to add to your nitro to make a toner coat. from your description it sounds like you want to make the ash white but translucent? make a toner with some white 844 colorant added to your nitro. make samples of different mixtures. maybe measure your mixtures in parts I.E. 100 parts nitro to 1 part white 844 etc etc. With your neck use the Mohawk dyes to make a toner with yellow dye and maybe true brown to dirty the yellow up a bit to get that aged amber look. get your first several coats of clear sprayed up and sanded out. make sure your grain is filled and all the defects before you start spraying sealer coats or you will burn through the color during sanding. Keep your toner coats thin and build the color up slow. samples samples samples... stripping a guitar is not fun.. been there done that.
