Exterior grade stain match
7/2/15
Matthew Thomas
I'm starting in on a project building a batch of "covers" to conceal A/C condensors at a commercial building. I did a mockup out of redwood and finished with Penofin natural. Now, the designer wants the finished units to match a Sherwin-Williams paint color (Sandy Ridge) but have it be semi-transparent to see the wood grain.
This seems like a tall task given the underlying wood color. Is there an exterior grade hardwood that takes a stain well like alder does?
7/2/15       #2: Exterior grade stain match ...
Robert Member
For a hardwood that's sitting out in the open elements, Oak might be the way to go.Its light enough to get to your stain color. I suppose you could bleach the Redwood but don't guarantee it for any length of time.
You could experiment with the Sherwin Williams over the Oak and see how it looks.
Try the color mixed in an oil base exterior Paint and reduce it to make a stain.
7/3/15       #3: Exterior grade stain match ...
RobertJ
Mahogany is the perfect choice for an exterior application. Easy to stain and coat with 2K Poly or traditional Varnish.....think of a boat finish.
7/6/15       #4: Exterior grade stain match ...
JeffA
If these things are exposed to the direct outside weather, they will look like crap in 6 months. I'm not sure about oak and the tannins. They will turn black if not mistaken.
7/6/15       #5: Exterior grade stain match ...
Kevin
use the product below in KPG Tan. should do the trick.
King Colorboard
7/6/15       #6: Exterior grade stain match ...
Kevin
sorry. did not see "wants to see wood grain"...
7/7/15       #7: Exterior grade stain match ...
John Member
Spanish cedar and cypress are exterior grade woods that are light colored and should take stain well.
John
