Cracking in MagnaKlear
7/17/15
Terry Stone Member
I had been using MagnaMax for several years with excellent results until one of my employees sprayed it over a set of doors that we had finished white with pigmented lacquer (he said he thought putting a clear coat over it was a good idea). About a year later, the clear lacquer yellowed slightly, but enough to make the lady's kitchen cabinets look like they had been finished with two or three different colors. While it is not our practice to spray anything over the pigmented lacquer, I decided to start using the MagnaKlear anyway in order to keep our finish from yellowing. I have been using it for a while now, and never had a problem until recently. For whatever reason, the last coat (we put one coat of MagnaSand and two coats of MagnaKlear) is cracking. I have called my sales rep a couple of times, and even talked with a guy at ML Campbell. The rep thought that the lacquer was being contaminated somehow, that we weren't letting the stain dry enough or that there was a chemical in our rags that we were using to remove sanding dust between coats. We made sure to sand well, and even bought new rags rather than recycled rags. We made sure to let the stain dry overnight before spraying. Still on the final spray, the material cracks. I was told that the humidity will not cause this, however, some days we spray all day without a problem, and then some days, everything we spray cracks. The man I spoke with at ML Campbell seemed to think we might be spraying to heavy, and getting material on to thick. we have turned down the material on the gun, and I have gone back and watched them spray, and even sprayed some myself, and am convinced that we are not putting on to much material, but still are having problems. I am ready to try another type of material, and am thinking about conversion varnish, but have never sprayed it before.
If someone has an idea about what might be causing the problems with the MagnaKlear, I would like to hear it, as well as their thoughts on conversion varnish.
7/18/15       #2: Cracking in MagnaKlear ...
Thinking you aren't putting on too thick of film, and measuring how thick you are spraying is two different things. The rep will probably give you a film thickness gage, use it and see what you are really spraying.
7/18/15       #3: Cracking in MagnaKlear ...
Leo G
Cracking or wrinkling.
I stopped using MagnaKlear because it would randomly wrinkle and ruin the job. Started after they started putting blue 60 day stickers on the cans. Never happened with the orange 120 day stickers.
I believe they reformulated it. They deny it. But I used it for 3 years and never had an issue. Blue stickers and then problems. I use Krystal now.
7/19/15       #4: Cracking in MagnaKlear ...
Terry Stone Member
Thanks for the responses.
