Setting up a AAA pump
7/20/15
Pdub
We've been spraying with a CAtech Bobcat for some years now. It's pretty much my finisher or I setting up/ using it and we generally just leave it at the same setting and adjust viscosity of the finish. We've now got an apprentice we're trying to train and we realize that we don't know (forgotten) the real "scientific" way to set up the air and fluid pressures. We just kind of go by feel and experience.
Can anyone offer a better, more thorough explanation of how to set the 2 pressures that we can pass along?
7/20/15       #2: Setting up a AAA pump ...
JP Member
CA Tech Has a video on their website that shows this in detail.
7/22/15       #3: Setting up a AAA pump ...
Gforce77
The video is a good setup guide, I would make a list of all the things you do like dealing with a clogged tip, maybe turning the pressure down a little when spraying inside cabinets, etc, all those things you do he'll probably not know until he experiences it, maybe you could save him a little time with the learning curve, unless he has a lot of experience with a AAA UNIT. good luck!
