quilted maple
8/2/15
jim russell Member
just did this quilted maple head board will be trimmed in wenge.
View higher quality, full size image (1500 X 844)
8/2/15       #2: quilted maple ...
jimmy cream
Wow.....
dye stain I presume ?
8/3/15       #3: quilted maple ...
RobertJ
Looks like a piece of wild granite!
8/3/15       #4: quilted maple ...
John S
The veneer matching leaves something to be desired. The two leaves on the right are slip-matched, then a leaf from another flitch, then another leaf from the original flitch, but book-matched to the first two leaves. I would have gone with a flitch match myself, it would give a more uniform look across the panel.
8/4/15       #5: quilted maple ...
Jim
John
I've never worked with quilted veneer. So don't really know, but could it be that quilted is so wild (changes so much)that normal veneer choices don't apply?
Amazing what hides under bark......waiting to be discovered. .......
8/4/15       #6: quilted maple ...
John S  Member
Hi Jim,
No, quilted Maple is cut into veneer the same as "regular" Maple, really no difference other than the figure in the wood. It is available in flitch form (1/2 log, cut into veneer) and I have utilized it many times.
That veneer face is just sort of a half way in between face; it's not flitch matched, but it's not random matched either.
8/4/15       #7: quilted maple ...
Was there a question about the headboard that I missed?
