Exterior finish problem
8/12/15
Walt Szybowski Member
We sprayed an exterior door last year. We used EuroX on it. Bottom part of the door are in direct sunlight. It is taking very high heat. The finish looked to be turning black. When we stripped some away we seen the wood actually looked burned. Is it possible for it to get hot enough under the finish to burn the wood?
8/14/15       #2: Exterior finish problem ...
Shane
What you are seeing is most likely water damage.... the bottom edge of the door is wicking moisture into the wood
