Foaming in a vacuum coater
9/1/15
Jim Guffey Member
Having problems with my finish foaming in a Vacuum coater. Have added a defoaming agent but I am reluctant to add too much as it is a silicone that may react with the finish?
Any ideas?
9/2/15       #2: Foaming in a vacuum coater ...
arthur grudko
You didn't specify the nature of your coating-solvent or waterborne. Assuming waterborne, and from my cursory knowledge of vacuum systems, it would be a nightmare to defoam a coating under these circumstances. The fast dry time of your vacuum system would make it impossible for the film to form and the air to come out of your system.
If it's a solvent coating, then you have a better chance.
9/2/15       #3: Foaming in a vacuum coater ...
JeffA
Yes, what are you using? Is it in the stain? Are you using 100% solids in the clear and UV curing? Need a lot more details. If you are adding defoamer it more than likely is a water based product. Is this product made for vacuum coating? It should have some defoamer in the formula but additional adds of defoamer at various times are not out of the question. I have over 10 years of vacuum coating experience. I have never seen the defoamer from a water based stain cause any issues with the clears. The defoamer breaks down rather quick in a vacuum coater as compared to any other method of finish application.
