CV on flex molding -- 0 --
10/12
I have a job with an inside radius crown molding that I need to paint. It is a resin flex molding. I was hoping to use the same pigmented conversion varnish that I am using for the rest of the job. Has anyone had success with this? My supplier said that it is not made to bond to plastic.
10/12 #2: CV on flex molding ...
Website: http://www.lrgwood.com
I've stained and cleared flex molding with a pre cat and had no issues with it. Pretty sure the same would work with a post cat.
View higher quality, full size image (800 X 597)
10/13 #3: CV on flex molding ...
Thanks Leo. I guess I'll test it on a scrap and see if it sticks.
10/13 #4: CV on flex molding ...
why not have a latex matched correctly and reduce/spray.... id sure hate to go back and redo everything after it all shrank down and cracked /peels off
10/14 #5: CV on flex molding ...
On a side note... Sherwin Williams does make a special waterbased bonding primer for plastics that you can use waterbased or solvent coatings over after it properly cures from their product finishes division... not the retail house paint stores...
10/15 #6: CV on flex molding ...
Website: profinisher.blogspot.com/
Just go to your automotive paint store and have some paint for plastic bumpers and car parts matched to the color you are using.
10/17 #7: CV on flex molding ...
Thanks for the responses guys. I was hoping to be able to use the same product for everything. I have used different products in the past and they aged differently and looked bad. I did a test and it seems to be sticking. I have some time to let it cure before it has to be applied so I can see how it holds up. I'll look into the primer you mentioned Shane. When I spoke with someone at the local commercial coating division they said they didn't have anything like that. You don't happen to have a product number do you?
12/18 #8: CV on flex molding ...
E61W525 Kem aqua plastic bonding primer... sorry for the late response
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
