Floor Finishing Problems
11/15/15
jonmcay Member
I recently was trying to talk a customer through refinishing their floor. They decided to use poly and everything went fine until after the third coat. They waited a week before moving furniture back in. Now they find the poly didn't dry properly. They are getting marks from the carpet and furniture . I told them the proper steps to sanmding between coats and not apply too thick. Any ideas about why it isn't drying properly ? Thanks any help would be appreciated. This has me puzzled.
11/15/15       #2: Floor Finishing Problems ...
Mitch Suber  Member
Website: subercustomshutters.com
I would first consider the finish was not stirred or mixed properly. I had this happen once, due to being rushed or maybe too many hands opening and putting down the finish. The change in gloss was a give away when this happened, plus the finish not curing correctly. Looking in a can of clear can be deceiving compared to looking at paint, to see if it is mixed well.
11/15/15       #3: Floor Finishing Problems ...
Pete Anderson
Website: http://petesfloors.wordpress.com
It was most likely that the first two coats of finish weren`t cured enough for the third coat to dry properly. Since poly cures from the top down the first coats need to cure for several days to two weeks to keep the solvents in the third coat from etching into the first two coats. This mess will cure over time, but if there is a thick film it will stay soft until the solvent from the first coat has cured, along with the subsequent coats. A final coat after everything has cured will make the surface even.
11/16/15       #4: Floor Finishing Problems ...
Joel
I made the mistake of using minwax thick poly when I re-did mine. It was horrible. Same problem. I called the tech and he said you can wipe it down with mineral spirits to reactivate drying. He said it happens all the time with their poly products. Least he was honest!
11/16/15       #5: Floor Finishing Problems ...
jonmcay Member
Thanks for all the help. I did my floor with varathane oil based poly and didn't have any problems at all.
11/17/15       #6: Floor Finishing Problems ...
jimmy cream
" wiping down " a thick coat of poly/varnish with mineral spirits will do little to re-activate the curing process . solvent poly is a varnish , and needs to be treated as such . technically its a reactive finish (even the minwax version ).....it cures by chemical reaction .....and re-introduction of its solvent has little effect on it . if a second or third coat is applied over a coat which is not cured , you will have a mess .
oh yeah....high humidity will slow the curing process ......a lot .
11/18/15       #7: Floor Finishing Problems ...
Joel
I should like to add that my mess did dry hard after about 3 weeks with fall humidity.
