Finish End Panels Veneers
12/2/15
Randy Stone Member
Website: http://www.dovetailconstruct.com
I want to build my 12" deep upper cabinets to continue over the fridge without increasing the depth just so I don't have any finishing on the side to deal with. Do most of you do this with Euro style when providing a cabinet with prefinished doors ect. to avoid as much painting as you can?
Also, When you do have a end panel where a 24" deep cabinet has a 12" upper bumping into it and your using 2 sides melamine on the 24" partition do you use the sticky backed veneer? I used it twice before. Once with good results (when I did the finish) and once with bad de-lamination when others did the finishing.
12/2/15       #2: Finish End Panels Veneers ...
Dave Edgerton  Member
Are you being serious?
12/3/15       #3: Finish End Panels Veneers ...
Randy Stone Member
Yes , Its a serious question. Not all of us are of such high intellect as you apparently are. If you don't like the question ignore it. But then this is probably where you go to act the intellectual bully that you appear to be.
12/3/15       #4: Finish End Panels Veneers ...
mikeg
Randy,
I'd have to say no. Avoiding as much painting as you can? Once you are set up to paint, an extra couple of panels or sides isn't usually enough to matter too much. I suppose if you were tight on time, budget and material, this might suggest a different response.
Veneer over melamine? Frowned upon, but if those are the cards you have been dealt, do sand off the melamine, yeah?
12/5/15       #5: Finish End Panels Veneers ...
Leo G
If you are doing melamine interiors on a painted exterior then you can buy the glue back melamine.
It has melamine on one side and a surface that is usually meant to put a laminate on. It works great for painting. Just a very light sanding and prime it.
It does still have a slight texture like melamine since it's a bonded fused product similar to melamine. I've used it for years and haven't had a failure.
12/6/15       #6: Finish End Panels Veneers ...
Randy Stone Member
Thanks Leo, I've seen that product before and the surface felt wavy. I was afraid the finish would reflect the wavy surface. Good to know it works. Thanks.
