Gravity feed gun recomendations
12/6/15
Tom Gafgen  Member
Website: http://www.TPGCABS.com
I use a Kremlin AAA most of the time and get excellent results but I need to get a new gravity feed gun for small jobs and samples . Looking for a gun that will give a great finish and also recommendations on tip sizes for clear and pigmented CV .
Thanks for your help Tom
12/6/15       #2: Gravity feed gun recomendations ...
nick
Since you'll be spraying CV a gun with stainless steel fluid passage is a must.
I like a 1.4 for clear and 1.7 or 1.8 for pigmented.
a Binks M1G (93 air cap, 94 & 97 nozzles) or their new Trophy series (I have the LVMP set-up on a pressure feed gun and the finish quality is as good as any spray gun I've used) will fulfill your requirements and make it easy to switch out tips as one needle fits all nozzles. Plus part are easy to get and they are fairly priced.
Another convenient option are CAT guns (they're pretty much Binks copies) they offer packs that come with an assortment of needles and nozzles so one stop shopping. I prefer their CPR air-cap to their HVLP air-cap. Expect to pay $300.00 to $450.00 new retail or less on Ebay if you can find what you're looking for
12/6/15       #3: Gravity feed gun recomendations ...
RobertJ
I have a C.A.T. ('Jaguar') gun as well....and I also work with the Kremlin 10-14/MXV gun too.
The Jaguar is a fine gun; just like a Binks!
12/11/15       #4: Gravity feed gun recomendations ...
B
I would recommend Anest Iwata LPH 400, I use it primarily for water base and CV/pigmented CV. Works great with that star pattern tip makes it lay better
12/11/15       #5: Gravity feed gun recomendations ...
jimmy cream
I bought 2 Devilbiss CVIs . they come with transtech and hvlp air caps . the transtech needs about 30 psi , the hvlp about 19 .
Ive sprayed clear and pigmented cv using the 1.3 or 1.4 needle . im sure a 1.8 would be awesome too .
full retail is around $350 . but I watched patiently and scored mine for around 270 apiece .....iirc .
12/11/15       #6: Gravity feed gun recomendations ...
jimmy cream
theres 2 of the cvis on e-bay right now . 1 auction and one buy it now at $280 .
12/30/15       #7: Gravity feed gun recomendations ...
Robert  Member
Not sure if you made a move, but I'll tell you I second Nick advice as I too have the CAT gun and since I bought it a couple yr ago, I rarely use my other guns ( binks & devilbiss).
Same for me, using there CPR air-cap to their HVLP air-cap.
One thing for sure, there may be other "better" guns, but this is one you will never regret buying @_# ....
