Polyurethane & warping -- 0 --
12/8
Hi...
I purchased a raw amp cabinet that has a 1/4" cherry facia (22x10) on the front that is glued to the white pine cabinet. On the inside I sealed it with a diluted varnish and the outside I used a polyurethane finish. This is how I normally finish a cab. Now the facia has warped and pulled away from the cabinet. I live in the Denver area which has very low humidity. Was the warping because caused by the way I finished it (the poly contracted the wood) or due to the dry climate and/or construction of the cab. If it is the finish method, what is a better way.
Thanks for your help!
Jeff
12/8 #2: Polyurethane & warping ...
Not your finish. It is 100% due to the differential in wood movement with the Cherry being laminated to the Pine. Get your money back.
12/9 #3: Polyurethane & warping ...
Thanks David... I'm working with the builder to get it fixed. I just wanted assurance that it wasn't something I did. I know that our extremely dry climate can cause havoc with wood - problems most of the other parts of the country don't have. Thanks again!
12/9 #4: Polyurethane & warping ...
Was the veneer by chance glued on using contact cement?
12/9 #5: Polyurethane & warping ...
Hi Rick... Not sure, he normally uses wood glue..at least on the box joints because I will occasionally see dribbles.
12/11 #6: Polyurethane & warping ...
Woodworking 101. No cross grain construction! Pine is long grain, cherry is short grain. Wood shrinks in width, not length. The cherry shrank, the pine didn't.
12/11 #7: Polyurethane & warping ...
Thanks.. He must have been sick that day! Normally when he uses the facia pieces, they are much smaller (2") at the top and bottom and then a baffle screwed to cleats make up the majority of the middle. Since this is a head cabinet (no speakers, just the amp), he was trying to do something special by doing the whole front as a facia with just a cutout at the bottom for the amp controls. I've cut off the front with a table saw and roundover'd the edges. I'll install cleats on the inside and he will make a new front that will fit inside, against the cleats and attached with screws. Not as nice as his original concept, but a more traditional look...which should work. I wished I was better at making box joints and using my router. My expertise is with the electronics. I've attached a pic of one of my pieces of work. Thanks to all for your comments and education. Maybe I'll try to spend more time in the wood shop!
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
