Stain Match - 49, Me - 7 - Fourth Quarter, Help!
12/20/15
Jason Yeager Member
Hello,
I received such great advice last time I posted I thought I would give it another shot.
I have a stain match that I have been working on, and thought I had it absolutely nailed, so I went ahead with the doors. I used two stains to get the color, first, Ebony ML Campbell wood song 2 stain to get the dark color, and secondly a BAC wiping stain from Sherwin Williams that was a match to try and get the red mahogany color in the door. Well, despite the panel I used to get the match looking perfect, the doors don't have enough red in them which is noticeable after I have sealed them. I have sealed the doors and have taken a picture to show where I am at, I am wondering if you guys have any ideas on how to correct this now that I am at the sealer stage. The doors I am trying to match have the big ugly sand throughs in the picture I have attached, and I have three of my doors in there, which you can see don't have enough red (and the dark portions aren't dark enough but not sure what to do about that now) Thanks in advance, looking for a miracle comeback, trying to get this done by Christmas.
12/20/15       #2: Stain Match - 49, Me - 7 - Fourth Q ...
Nick
The standard procedure at this point would be to apply a toner. But from your pictures it look like the new doors are more opaque/even toned then the originals so chances are a pigmented toner wouId cloud things up more...that said a toner made with eyes may work. With that said; I've down this road and the answer that worked for me ended being (l'm sorry to say) lots of elbow grease, lacquer thinner and a stack of maroon scotch-bride pads...the goal being getting 50% or more the stain out of the wood and then staining on top with the color needed to get the look you're after.
12/20/15       #3: Stain Match - 49, Me - 7 - Fourth Q ...
Nick
PS. Being shy on the red is a classic case of making a match under fluorescent light, if this what you're doing make sure to check your match under sunlight or bulbs with a fuller spectrum of light.
12/20/15       #4: Stain Match - 49, Me - 7 - Fourth Q ...
John Member
If you need to shift it red you could spray a red dye toner. Transtint dye is soluble in water, alcohol, lacquer thinner, and a few other solvents. I often use it in dewaxed shellac as a toner under my water borne topcoats, but I sometimes add it to my topcoat to get a subtle color shift if I've already applied a coat of finish, as you have. Unlike pigmented toners, Transtint toners will give you nearly transparent color without masking the grain, etc. A bottle of Transtint goes a long way.
John
12/24/15       #5: Stain Match - 49, Me - 7 - Fourth Q ...
Jason Yeager Member
Thanks Guys,
Yeah, we sanded them off and are going at it again............ho ho ho lots of fun.
Merry Christmas
