mystery finish problems/questions
1/21/16
the google
we have a countertop that we finished in october for a clients beach/vacation house. we did the job for a contractor who picked up and installed it himself so i don't know all of the details.
the finish (2k poly, dull sheen) is failing in select areas of a 36 sf walnut countertop. the select areas are essentially 10" square sections (approximate, and i'm getting this information second-hand, without physically seeing the countertop) and they are in different areas in all parts of the countertop. one spot might be on one board at one end and another area is on the other side, running over multiple boards. there is nothing mechanical (microwave, wine fridge, etc.) under the top and no hvac running under the cabinets under the top. the information that i'm receiving indicates that there is no outside factor causing problems.
the failure/problems are that the top is extremely easy to scratch in these select areas. i don't know if the scratch marks are the finish lifting but they are showing white marks (similar to what you could see with a lifted finish). the builder has said that you can scratch the finish with gentle pressure from you fingernail.
now, my finisher, whom we separated with two months after this job was completed, missed that it was dull and finished it as satin. we let it cure for 12-36 hours before discovering his mistake and promptly recoated in dull. we would have scuffed with 320 paper and mostly likely maroon scrotch-brited the whole top after the 320. we've shot an extra coat in this exact same manner (time passed and scuff preparation) many, many times before without any know issues.
any guesses? i would think that he would have adequately sanded the entire top prior to shoot dull, and if not, we have failures everywhere instead of in select areas. this is first time we've ever seen this and the first time i've ever heard of this (and i've read most of the woodweb archives).
1/21/16       #2: mystery finish problems/questions ...
dar
some 2k like ica , dont react well to long dry oil based stains, any chance you stained it with this?
1/21/16       #3: mystery finish problems/questions ...
the google
dar - i wish (only because it might be more obvious as to what is going on). no, the top is completely natural. we sprayed one sealer and two top coats. ilva.
1/22/16       #4: mystery finish problems/questions ...
Rick Mosher
Sounds to me like it was fully cured and then not scuffed enough in some places which caused an adhesion problem.
1/22/16       #5: mystery finish problems/questions ...
the google
rick - i'm thinking fully cured means 20+ days. i cannot remember for sure but i know that the maximum amount of time between discovering this error and reshooting would have been three days (the weekend). i'm also baffled because my finisher would have (and should have) scuffed all areas the same. was 320g not adequate after an extended period of time?
1/22/16       #6: mystery finish problems/questions ...
Rick Mosher
320 would have been OK but I think it may have just been a quick scuff with a scotch brite pad and he may have not hit some areas really good with that either. I am just guessing here but 2K urethane usually bonds really well so something had to happen to cause the problem. Having trained a few finishers in my day I have seen this happen before when someone was in a hurry to get something out. I guess it really doesn't matter now you will have to remove the bad layers and respray at this point.
