tack cloth
1/26/16
scott
Just before we spray our finish we blow air with a clean cloth to remove excess dust, except sometimes i still find a light grit. I have used my bare hand to make several passes and it seems to remove the excess. What is everyone else doing as I can't believe that a bare hand is the answer. We've been told not to use a tack cloth but is there something else. We spray both pre catalyzed lac. and CV.
1/26/16       #2: tack cloth ...
kevin
ive never had an issue with good old tack cloth. not once in my long experience.
1/27/16       #3: tack cloth ...
CraigM
I use tack cloths on everything, post-cats, CV, 2K's, pigmented, clears, and have never had an issue.
1/27/16       #4: tack cloth ...
Howard Member
The reason you might have heard not to use a tackcloth is if you are using a waterbased finish. There can be contact issues from residue from a commercially prepared tack cloth. Naturally this is not the case if you are preparing you own, say with shellac or if you are simply doing a wipe down with naptha or mineral spirits.
2/1/16       #5: tack cloth ...
JeffM
Never had any issues with tack cloth. Never spray water based though either.
