Fish eyes in Conversion Varnish
1/25/16
David  Member
Fabricated 1 1/2" thick Pine tops for a kitchen. The specified finish was EZ DO wipe on poly gel from John Boos. Looked great. After the tops were in the space for about a month the client decided that she wanted a darker color on the tops. Due to the finish I originally applied stain would not absorb into the wood. I suggested that we refinish the tops with a toner of NGR and conversion varnish. Did a sample and it looked great. Now we are getting small fish eyes in the finish. We did sand and do a sealer coat of CV before we attempted the toner. The question is how to fix what I have or am I making new tops?
1/26/16       #2: Fish eyes in Conversion Varnish ...
Leo G
Have you tried fisheye remover. It's basically pure silicone that makes the finish into one big fisheye. And then that eliminates the problem.
1/26/16       #3: Fish eyes in Conversion Varnish ...
Mastercabman
Did you sand the tops to bear wood?
1/27/16       #4: Fish eyes in Conversion Varnish ...
David  Member
Thanks for the response. I did use fish eye additive to no avail. So I'm back to bare wood and starting over. We always want the magic bullet but not this time.
1/27/16       #5: Fish eyes in Conversion Varnish ...
Leo G
Did you ask the client if they used Pledge on the surface. Because if they did, sanding down to raw wood might not even help. After sanding it down I would bath it in several different solvents wiping with a clean cloth several different times.
2/9/16       #6: Fish eyes in Conversion Varnish ...
jerimiah Member
To combat the fish-eye problem sand the finish surfaces with 400 grit then clean the surface thoroughly with alcohol (denatured) after a very light sanding with 400 grit ,NOT a heavy wash,just dampen a rag and remove and oil spots that won't allow your materials to flow evenly,fish-eyes are chemical reactions,like oil and for extra precaution add a few drops of fish-eye retardant.
View higher quality, full size image (1520 X 2688)
