pinholes distress furniture
3/2/16
ricklam Member
Website: http://www.docteurdumeuble.com
hello everyone...new here..i have a problem with a table which needs refinishing...the table has some distress marks which I believe were man made...are actually series of small holes here and there on the legs...top...skirt etc...my client swears they were not there before but there were no signs of wood worms anywhere or sawdust for that matter...well she is 90 years old....but any ways...my dilema is that she absolutely wants these holes gone....what would you suggest ?...especially since the color is light... any way i can upload pictures here ? rick
View higher quality, full size image (1494 X 2656)
3/2/16       #2: pinholes distress furniture ...
kevin
if your planning on just a scuff and recoat, then i have had great success with Mohawk Quick Fill Burn In sticks. They are kind of right in between wax sticks and traditional burn in sticks. You can heat them up with a lighter, rub them into the holes, then scrape off excess with a plastic razor blade (or a credit card) . They are stiffer than wax stick so they dont shrink or pull out of the hole so easy. They come in a bunch of colors so chances are thats all you will need. I do have a full set of blendall sticks as well that i use to alter the color if necessary.
So, fill the holes, replace the color if needed, scuff, recoat.
Or if your going to sand everything back down to bare wood then the repair is obvious. Wood filler.
3/2/16       #3: pinholes distress furniture ...
kevin
oh, and i do agree with you that those are man made distresses that were part of the original finishes. Maybe she got a new set of eye glasses recently.
3/2/16       #4: pinholes distress furniture ...
ricklam Member
thanks kevin....she already has glasses 1 inch thick lol....i agree these were man made...i know about the mohawk products....i will opt to tint the wood filler same color as table...i am wondering if they will show...
3/2/16       #5: pinholes distress furniture ...
kevin
if they show after you seal then should be easy to blend in with the mohawk blendal sticks. ive hidden tons of mistakes with them. can even faux grain with them on burn throughs in veneer. Great product in the right hands
3/2/16       #6: pinholes distress furniture ...
ricklam Member
cheers
