Tinted laq filling shelf pin holes
3/20/16
Joel
Hi, I mostly use clear finishes but have a built in to do painted red. I am wondering if primer plus topcoat will build up causing problems with the shelf pins. Am I worried about nothing? Thanks...Joel
3/20/16       #3: Tinted laq filling shelf pin holes ...
denny Member
Nothing that a very small amount of persuasion from a Light Mallet/Hammer will not take care of.
3/21/16       #4: Tinted laq filling shelf pin holes ...
Joel
Thank you Denny
3/21/16       #5: Tinted laq filling shelf pin holes ...
denny Member
Before you thank me.....this is for those little, metal brackets for shelves.?
If you are looking into the cabinet, there are 4 smallish holes...2 on the left side and 2 on the right side.?
You push a bracket into each hole, and they support the 4 corners of a shelf.?
If that is the case...yes.
I have seen that scenario many times. Most of the Paint/Lacquer build-up is on the surface of the cabinet, and not down, in the hole.
A rubber mallet will tap them right in...done it many times. :-)
