air increase for kremlin
3/20/16
Michael Horrillo
Website: http://properwoodfinishing
I have run a Kremlin 10-14 for over 15 years.
If I increase my air flow by going from a 1/4" quick disconnect to a 3/8" disconnect, will I notice any better air fan control or spray efficiency? The system was set up with 1/4" lines from the re- seller.
3/20/16       #2: air increase for kremlin ...
Very doubtful, I think the system draws 2 CFM
3/22/16       #3: air increase for kremlin ...
chris
which model gun are you using.
The new xcite model has better fan control than earlier models
3/22/16       #4: air increase for kremlin ...
Michael Horrillo
Website: http://properwoodfinishing.com
First generation Excite.
3/23/16       #5: air increase for kremlin ...
chris
what tip do you use?
AAA is most efficient spray system. you can play around with different fluid pressure but the xcite is their newest gun.
i use 1/4' hose and am happy with the results
3/23/16       #6: air increase for kremlin ...
Nick
Of course, when you're looking for more control, be fan size, fluid volume or spray particle size just change over to a pot/gun set-up.
3/23/16       #7: air increase for kremlin ...
Joe
On a 10:14 there is no need to change your air ID. all your control is tied into you fluid/air reg settings along with the cut of your tip....what are you trying to achieve ????
