Re: Paint or Stain on Wood Products
3/28/16
Tommy
How do you make paint for wood based products?
Also, are there any natural food coloring or oils that can applied to wood to make different stain colors and enhance the wood finish?
3/31/16       #2: Paint or Stain on Wood Products ...
denny Member
What do you mean by "Make Paint".?
Are you opposed to using all the stuff that is available from the manufacturers.?
Almost the sane thing with stain.....there are so many colors available, either as dyes or stains.
If you need to match a stain, you can still by the Colors In Oil, UTC is a pretty big name in that arena.....just mix with Turps or Paint Thinner.
If you are talking about Traditional/Historical methods of making finishes, I am not the guy to answer that.
good luck
4/18/16       #3: Paint or Stain on Wood Products ...
Dustin Member
Website: http://www.hardwoodflooringminneapolis.com
You can cut latex paint with water to get a transparent stained sort of look.
4/20/16       #4: Paint or Stain on Wood Products ...
marvinkhenry Member
Paint or Stain, that is generally the question. If you are doing a steel door, you will want to paint both sides of the door. If you are doing a fiberglass composite door, you have the option of staining or painting your front door.
impact windows boca raton
