Recommended Finish for Tops on Red Oak
4/25/16
Dave Member
Website: http://davescustomservices.com
What products are you using to get a durable finish for table top, bar top, and counter tops on Red Oak?
I am interested in solvent based coatings that I can spray and dries quick that does not raise the grain or cause grain issues on the open grain of Oak like water based products do but will be durable like a poly.
4/25/16       #2: Recommended Finish for Tops on Red ...
2K Poly
4/26/16       #3: Recommended Finish for Tops on Red ...
Joe
2k poly ilva is a great product build you base no sanding between sealer coats sand and one heavy top 6mils turns out great real easy to work with.
7/14/16       #4: Recommended Finish for Tops on Red ...
Y. Heller Member
Sea Grave conversion varnish
