Help to achieve Grey / Beige Finish
5/2/16
Matt
I am trying to achieve a warm grey beige finish on a wood project with white oak but i can't seem to replicate this color. It seems like everything i try results in a color that is much darker. See image for an example of what i am trying to achieve.
View larger image
5/2/16       #2: Help to achieve Grey / Beige Finish ...
Matt
Another example
View larger image
5/2/16       #3: Help to achieve Grey / Beige Finish ...
2 part bleach
5/3/16       #4: Help to achieve Grey / Beige Finish ...
chris
check out WD lockwood stains.
5/3/16       #5: Help to achieve Grey / Beige Finish ...
That's a pretty even color, but you might want to try a base light colored stain and a darker glaze.
5/4/16       #6: Help to achieve Grey / Beige Finish ...
Mark karda Member
Try brushing on ammonia
5/4/16       #7: Help to achieve Grey / Beige Finish ...
Dustin Member
Website: http://hardwoodflooringminneapolis.com
Rubio Monocoat makes a product called fume it will get that exact color. If it's too gray add water to dilute.
Another option is WOCA driftwood lye or gray lye.
Some more info on some of these things
5/6/16       #8: Help to achieve Grey / Beige Finish ...
ThomasFR
Star Chemical had a product called "Bleach Tone" I'm sure it's in the Mohawk line now. We would spray multiple reduced thin coats (on bare wood) till reaching desired opacity & follow with wet glaze, or wiping stain.
Kind of a micro ceruse look. Most common use in 1950s 60s was to generate a contemporary "fruitwood" finish on older mahogany or walnut pieces. It was the first thing came to mind looking at the pics.Did similar looks using heavily thinned pigmented lacquer, trick being to not have a film finish build too much before stain/glaze. Samples & practice required but actually a simple & repeatable process. Good luck whatever you try.
5/9/16       #9: Help to achieve Grey / Beige Finish ...
kevin
i just did this the other day for a friend of mine. very simple to achieve that weathered gray look.
heavily dilute black wiping stain with mineral spirits. rag on, rubbing into the grain especially around knots/cathedrals. then wipe dry with clean rag. Next do the same thing with diluted white wiping stain. Seal, topcoat dead flat.
Of course if you need to alter the final grey, you could always shift the tint on the second (white) coat of stain.
It comes out very nice, and believable as authentic weathering.
5/9/16       #10: Help to achieve Grey / Beige Finish ...
kevin
PS. im referring to the board that the letters are on in the photo and not the letters.
5/16/16       #11: Help to achieve Grey / Beige Finish ...
Thom
I recently had to match this finish. Although I applied it to alder and birch, it should still work on oak.
First lightly spray on white Amazing Stain by MLC or make your own white wash by adding 10% sealer to white stain.
Then stain like it was raw wood.
seal, sand, topcoat.
I had to be careful to not put too much white wash on, for it will seal the grain and be too light but when it did happen I just toned with the stain like a glaze.
8/13/19       #12: Help to achieve Grey / Beige Finish ...
Nicholas
Website: https://allseasonstreeserviceofelgin.com
Diluting a darker stain with mineral spirit is definitely the way to go. Try it first on a scrap board then when you feel like you have the right hue you can apply it where you want it to go. Good luck.
8/17/21       #13: Help to achieve Grey / Beige Finish ...
Arnold Member
Website: https://epoxyatlantaga.com/
I have a similar problem but my wood is way too lighter than yours. I will try some of the suggestions here and will see how it will end up.
2/10/22       #15: Help to achieve Grey / Beige Finish ...
Home Remodeling Wheaton
Website: http://www.homeremodelingwheaton.com
I love the beige finish, thank you for this post!
2/1/24       #16: Help to achieve Grey / Beige Finish ...
Hiliam
where did you get the paint?
    • Supergrit Abrasives
