clogging tips in Kremlin guns
5/17/16
Dan Cook
We have a Kremlin airmix gun and pump. We love it and it has given us years of good service, but we keep getting buildup around the fluid nozzle behind the aircap which causes the gun to spit at times. We end up having to take it out and clean it real good but eventually it comes back again. We only use this pump for Magnamax clearcoats and this is the only pump/gun that seems to do this regularly. The other Kremlin guns we have for paints and sealers don't seem to have this problem as much.
5/17/16       #2: clogging tips in Kremlin guns ...
What I hear is you keep the finish in the gun all the time and the only time you clean it is when it gives you issues.
Do you run the O ring screen behind the tip? That needs to be removed at the start of every spray session and cleaned with a brush. The gun should be flushed out with thinner at the end of each day. You could probably do every other day.
Bottom line is a clean gun is a happy gun. If you let the finish build up in there you are asking for problems.
5/17/16       #3: clogging tips in Kremlin guns ...
Shane
Sounds like a s.o.p. problem. If you want your equipment to run properly I suggest starting now to properly flush your system. Give the pump several clean flushes with lacquer thinner if possible or acetone at the least... Pull the gun screen and soak and scrub.... take the gun nozzle off soak and scrub.. make sure all the air holes are clean and clear.... Take the gasket out of the tips and clean inside the tip very well.... throw the gaskets away and buy several new packs. Flush every time you finish spraying very well with clean solvent.... We even give ours a good soaking over the weekend with polychem primed into the pump, hoses & gun.... it will loosen up any crud hanging around that didn't get flushed... pump it back into clean container and use it over and over... We can't buy lacquer thinner here (Over our VOC limit)and use C.V. so a good polychem flush every week is a must for us. If you cut open our fluid lines or disassemble a pump here they will be spotless as well as the nozzles and air caps /tips.... We have a 1/2 gal. crest ultrasonics heated ultrasonic cleaner we soak tips in overnight in polychem and they keep super fresh at all times..... Cleanliness is the key... nothing more frustrating than trying to fiddle with a gun when you could spray a whole setup instead... if your stuff is clean and the tip gasket is good you should have no material spitting out of your aircap holes... now if you start getting buildup that blows off your tip onto your work piece then you need to adjust viscosity...
