How would you approximate this finish?
5/21/16
Any ideas?
TIA
Pat
5/21/16       #2: How would you approximate this fini ...
Thom
high build clear on rough-sawn lumber
5/21/16       #3: How would you approximate this fini ...
Man, that is ugly! I guess you can make it from just about any species of wood since you can barely see it! Plenty of base stain, color in the seal coat, then too much top coat.
5/21/16       #4: How would you approximate this fini ...
Thanks, I was referring to the distressing or rough sawing.
I have to use sq raised panel doors, I don't usually make them.
I guess as you said just get some rough sawn and skip plane.
Thank you for the input.
But was hoping for another idea on it. To get that look
5/22/16       #5: How would you approximate this fini ...
D Brown
Pat , I just completed a media cabinet and I needed to make it look rough sawn similar to your picture but we used the term Random to describe it .
I used a disc sander and made a jig to hold it so the heel would not come down and make contact with the wood because it would leave marks going in 2 directions.
The largest disc sander maybe even rent one will work better than the small one I used was a Makita like 5" disc bigger would be better .I could not find RS hardwoods from a circular saw only band sawed . It was easy and creative but very Random and not at all like what I normally build . Good luck.
5/22/16       #6: How would you approximate this fini ...
Thanks D, that is along the lines of what I was thinking.
Maybe a jig that pivots the sander as well as holds it at an angle.
I was also pondering using a 20" disc sander somehow. Maybe feeding in the stock at an angle. But then I would have to build the doors.
I like your idea on this.
5/22/16       #7: How would you approximate this fini ...
D Brown
Pat , I tried the pivot idea but because the disc is rotating it caused road rash between the marks and actually sorta squigeld around out of control .
Better I found you need to hold the disc so the pattern is on the best looking angle to the wood . I moved the sander not the wood and just touched it down every inch or so or even randomly to emulate the rough sawn look. I then sanded to further add to the look and feel . I marked the wood before cutting to exact sizes .
5/22/16       #8: How would you approximate this fini ...
Thanks D
You used an electric?
Was the jig wood?
5/22/16       #9: How would you approximate this fini ...
Mike Member
Experiment with a cheap high speed steel blade like the ones we used to get with a table saw usually a combination blade but i think a rip would be better with not many teeth 18 or so. The kind you sharpen at home with a file then over set a few teeth and experiment.
I actually still use these blades when i want to rip some rough lumber that hasn't been edge jointed yet.
5/22/16       #10: How would you approximate this fini ...
D Brown
Electric Makita small disc sander and a wood jig to keep the disc on an angle and not allow the heel to make marks the wrong way .
5/23/16       #11: How would you approximate this fini ...
kevin
just a thought ---
a buddy of mine rented a flooring sander from home depot in attempt to refinish his oak floors. the machine was too much for him to handle and his floor looks alot like that now!! LOL
maybe check out the post in the Shop Built Equipment forum here, titled Frankensaw. should fire up some inspiration
5/23/16       #12: How would you approximate this fini ...
Thank Kevin,
That is perfect. Except I would have to then build the doors.
Which make sense. Just seems like less work to use D's idea.
Time to experiment.
5/24/16       #13: How would you approximate this fini ...
D Brown
Here is a look at the texture and a quick jig I made .
View higher quality, full size image (864 X 1536)
5/24/16       #14: How would you approximate this fini ...
Thanks D
5/29/16       #15: How would you approximate this fini ...
Dan / drbwoodworks
The center board is pushed through bandsaw with resaw blade just enough to scratch and gouge the surface , the same with the outer boards but with a tablesaw . Those boards look narrow enough to use tablesaw anything wider I would use a disk sander . Then push through wide belt sander to ease the roughest parts , and a whole bunch of ro sanding.
