Kem Aqua plus
7/6/16
Mike Member
I am going to try the Kem Aqua plus, i never used it before so i called my local SW store for availability and color pallet. He wasn't sure of either but said that maybe the colors would only be light or pastel because he only found a white base. So to anyone out their that use's this product is this correct?
Also do you usually shoot the clear over the colors for more durability? Thanks
7/6/16       #2: Kem Aqua plus ...
Nick
I switched from Target to Kem-Aqua plus a little over a month and 50+ gallons ago using both the clear and pigmented varieties, l don't have a handle on it's ways yet but l'm starting to...
It is not necessary to clear over the pigment but I have on 5 cabienet jobs already because the low gloss sheen was not glossy enough but the 50% + sheen was too glossy. Clearing over the pigment does improve on the already smooth feel but can be a PITA as the product does have a tendacy to leave what I believe are little surface tension pinholes in the clear...these can be overcome with a even 400 grit/fine to extra fine sponge grit sanding prior to clearing.
the white base can be tinted just beyond a pastel...say a medium base color ...you can tint to a dark medium base and beyond by tinting the clear. l have done this once so far and it worked great.
7/7/16       #3: Kem Aqua plus ...
Bruce Hand Member
Hello Mike if you require a darker tint just use the Kem Aqua. I ran into this problem also as the Kem Aqua plus can only tinted using 4 oz max per gal
I switched over to the plus a few months ago and have really like the product. I'm using a Kremlin Eos 15-25 pump, sprays and levels perfect
7/7/16       #4: Kem Aqua plus ...
Gary
We use Kema Aqua Plus on a daily bases, you can have any color you want mixed, we have a shop black that we use all the time that S.W. mixes for us
7/12/16       #5: Kem Aqua plus ...
al
I thought you could only get tinted from a commercial SW dealer. Is the plus product
now available at local SW stores?
7/12/16       #6: Kem Aqua plus ...
nick
I get mine at my local SW paint store...the stuff tints with their regular house paint or BAC colorants, no need for the 844 colorants.
12/12/20       #7: Kem Aqua plus ...
Brent Member
Gary, can you elaborate on how you got the KA+ to a dark black color? My sales rep assures me the pigmented base (white) can only be tinted into the pastel range... nothing darker. Are you tinted the KA+ clear base to the dark colors? Do you have an idea on what colorants they're using?
I have convinced my sales rep to give a go at tinting the KA+ clear base into something dark as a test... I assured her I would cover the cost of the gallon either way. I really like the KA+, but I need to be able to do dark pigmented finishes in addition to the pastels as the darks are becoming more popular recently.
    • Supergrit Abrasives
