Sherwood- cab arcylic
7/18/16
tom Member
Did some built in office cabinets for one of my customers. My customer picked a color from Sherwin Williams,I have always used ML Campbell pigmented lacquer with a clear coat on top. This is my first time using this product.I'm wanting to know if a clear top coat is need with this product. Iv'e read thru the spec sheets and no mention of a top coat needed.
I have two coats primer on and two coats of the colored cab arcylic. Seems like a nice finish.
View higher quality, full size image (800 X 450)
7/18/16       #2: Sherwood- cab arcylic ...
Dan
Why not just get MLC to color match the color. I've had it done a ton of times.
7/19/16       #3: Sherwood- cab arcylic ...
Alan
No top coat needed, however you can add one if you want extra protection from marring/scratching. But it is a good non catalyzed coating on its own. I find that it works best by adding a little M.A.K as a retarder to help it "relax" and lay down.
7/19/16       #4: Sherwood- cab arcylic ...
tom Member
Thanks Alan,
The retarder you mentioned,M.A.K. Whats the full name of it and where do you get it.
7/19/16       #5: Sherwood- cab arcylic ...
kevin
MAK = Methyl Amyl Ketone and is available from the same place you bought the paint.
7/19/16       #6: Sherwood- cab arcylic ...
Shane
Decent paint for interior cabinetry... no clear needed unless you want extra stain and mar resistance
7/19/16       #7: Sherwood- cab arcylic ...
Leo G
I don't recall ever seeing anything about MLC pigmented coats saying there should be a clear applied after. That's usually just a choice by the finisher. It's easier to fix a clear scratch then a pigmented one.
Since most clears will slightly alter the color of the pigmented coat I'd just go with the straight pigment painted surface and leave it at that.
But I agree with Dan. Just get the color matched with the brand you are comfortable spraying.
7/21/16       #8: Sherwood- cab arcylic ...
Apparently somebody still uses CAB acrylic. Might be stock left over from the mid 80's....
