white haze on cedar garage door
7/19/16
mainzy Member
There is a white haze on garage door clearcoat.it is on a cedar door.maybe it's from moisture? Will another topcoat clear this up.
7/19/16       #3: white haze on cedar garage door ...
What kind of cedar?
7/20/16       #5: white haze on cedar garage door ...
mainzy Member
Red cedar
7/20/16       #7: white haze on cedar garage door ...
RobertJ
Do you know the coating? Solvent or H20?
Moisture is trapped.
Don't try to add another top coat to the finish.
In other words, the current coating has failed and needs to be removed.
7/20/16       #8: white haze on cedar garage door ...
Matt
This is a common problem but we need more info.
What specifically are you spraying? Product, brand, what thinner are you using, what is the weather conditions, especially humidity.
I do not spray paint unless I have a humidistat near by, even with finishes that don't blush, because it helps me predict slower cure times.
7/27/16       #9: white haze on cedar garage door ...
mainzy Member
Thanks guys we are sanding failed finish of and restainig and topcoating.
