Stainless steel paint hoppers-- safety/spark/static an issue?
7/25/16
Matt
Good day folks,
We currently use, and mostly like, the 1.5 gallon cone shaped plastic hoppers from CA Technology on our 3 AAA pumps. But they have their drawbacks which I won't get into.
I have found a source for identical sized stainless steel cone hoppers (Toledo Metal Spinning) for a few dollars more.
I'm curious about making sure these things don't static-spark on us, and a ground wire would be quite easy to do.
I figured I'd ask around here for any suggestions from you guys who perhaps are more familiar with this situation than I.
thanks,
Matt
8/6/16       #2: Stainless steel paint hoppers-- saf ...
mike j
No need to get so complicated, I use an empty 5 gallon metal paint bucket and drop in a pressure pot plastic liner.
8/6/16       #3: Stainless steel paint hoppers-- saf ...
mike j
Just a note, with this set up the Kremlin pump is grounded to a metal pipe with the grounding clip supplied with the pump.
