How many coats hi build pre cat
9/2/16
Ryan Member
Hi everyone
I keep going back and forth with this, I spray my doors laying down so I am spraying around 5 mil , with Sherwinn Williams hi build pre cat, if I do two coats it finishes out at 2.5 mils DFT. It looks great, is this enough, I've been putting on 3 coats just to be sure but is this really necessary,I'm spraying with a AAA pump, no thinning my DFT is within manufacturers recommendations. Does anybody else spray two coats like this and how's it worked out for you over time? Is it all about mil thickness? I have read the posts here about this I'm just looking for some fresh insight, especially if there is someone who is doing this successfully or not.
9/3/16       #2: How many coats hi build pre cat ...
RobertJ
You need an electronic meter to properly assess thickness gauge. The 'woodwork' division of SW may have one you could borrow, or take them a sample board.
Link below.
Link
9/4/16       #3: How many coats hi build pre cat ...
JeffA
What does the TDS say?
9/4/16       #4: How many coats hi build pre cat ...
RobertJ
Are you using a first 'sealer' coat followed by two finish coats, or just two finish coats?
9/4/16       #5: How many coats hi build pre cat ...
Joel
One coat of sealer and two good wet coats is more than enough. I have seen shops just do one heavy coat and send it out the door.
