Water based clear coat too glossy-can I tone it down?
9/6/16
Justin long Member
I built a hard maple countertop for a client and used dura seal water based-poly satin sheen on it. I'm happy with the product however I was hoping to take the shine down a bit and don't know with water base if there's a safe reasonable solution?
9/7/16       #3: Water based clear coat too glossy-c ...
Robert Member
Top coat it with another sheen of your choice over it after a simple scuff sanding the existing finish. That it !
9/7/16       #4: Water based clear coat too glossy-c ...
RobertJ
How did you apply the Dura Seal, and when did you apply the finish? It may take a few days or a week to settle into a 'Satin' finish.
Final cure is about 30 days.
9/7/16       #5: Water based clear coat too glossy-c ...
Justin long Member
Thanks for the info! I sprayed it with an hvlp gun and only final coated it yesterday- and wasn't aware that the water based product took as long as a month for the sheen to adjust. Good news.
9/7/16       #6: Water based clear coat too glossy-c ...
jonathan mahnken
in my experience the sheen doesnt usually adjust down over the month long curing period. whatever you have a day or two later is what you will have. if the coating is thick enough and if its only one top then you could try knocking down the sheen with a white or gray nonwoven abrasive pad. otherwise recoat with a lower sheen.
1/22/17       #7: Water based clear coat too glossy-c ...
Jeff Member
Website: http://n.stuccu.com/s/Interlux%20Flattening%20Agen...
Have you considered a flattening agent?
The link is one type, but now you know what to look for.
I keep several types around, use them all the time to adjust finishes to what I need....
