Seeking advice fixing / filling pin hols in lacquer ?!
9/8/16
Robert Member
Hi all !
Doing some restaurant table tops with maple veneer ply & cherry.
Top them with some WB Polyester acrylic lacquer, 7 layers so far !
As soon as the 1st few coats i could see those...kinda of pin hols....appear !! ( see below pics)
Inevitably, those are from some “tiny” gap in the seams between the veneer & the cherry where the lacquer is still not filling it after those 7 layers !
Any recommendation on how to fill & fix this will be very much appreciated
Thks, Robert
View higher quality, full size image (1280 X 720)
9/8/16       #2: Seeking advice fixing / filling pin ...
Robert Member
Could you take a small artist brush and drop some finish just in those areas. Once dry, block sand if flush and apply a thin final topcoat.
9/8/16       #3: Seeking advice fixing / filling pin ...
Steve Member
The fact that you were approaching seven coats should have been the first warning. I suggest you check with your dealer; I think you are using the wrong product. Some other products are made for that and float a surface with one coat. Check manuf. literature. I am sorry that specifics escape my memory at the moment.
9/8/16       #4: Seeking advice fixing / filling pin ...
You seam is not tight on that edging. The lacquer is wicking into that seam. More glue or a natural filler rubbed in before final sanding and finishing. 7 coats is a lot. Make sure you can have that thick of film with the manufacturer. Often too thick will cause cold cracking.
9/9/16       #5: Seeking advice fixing / filling pin ...
ed
Super glue with the accelerator might work, you will have to sand down flush and re coat.
9/9/16       #6: Seeking advice fixing / filling pin ...
nicko
Robert is correct on the fix, it is called drop filling. I have used a tooth pick and let a drop of finish run off the end and drip into the pin hole.
good luck.............nicko
9/9/16       #7: Seeking advice fixing / filling pin ...
chris
there is going to be movement at that joint with the cherry moving causing cracking.
9/9/16       #8: Seeking advice fixing / filling pin ...
Robert Member
It kind of looks to me as if the joint itself is not loose but the solid Cherry stock is just a tad bit proud of the Maple. The coating is trying to flow from the Maple to the Cherry and that's whats causing the small finish gaps.
9/10/16       #9: Seeking advice fixing / filling pin ...
It'll take a day+ to drop fill all those!
9/12/16       #10: Seeking advice fixing / filling pin ...
The glue line was a bit dry. The first coat of finish flowed into the inconsistently spaced pinholes along the glue line. He never bothered to fill them and every coat exaggerated the initial pinhole.
We see this all the time with white primer. Before you go further than the primer it is necessary to fill every defect with putty, no matter how minor, because finish does not fill holes.
