Chemcraft 24 primer and top coat over UV plywood?
10/7/16
Folz Custom Cabinets (Joe) Member
Chemcraft 24 primer and top coat over UV plywood? If you scuff sand uv plywood will the product bond?
10/7/16       #2: Chemcraft 24 primer and top coat ov ...
Nick
a complete uniform sand ( no shiney spots) with 400 grit on a ro has worked for me.test on a scrap piece first to make sure you have adhesion.
10/7/16       #3: Chemcraft 24 primer and top coat ov ...
Kevin Member
I do it. However I sand with 120, then 150, then prime. Looking for a pretty aggressive scratch pattern for adhesion.
10/8/16       #4: Chemcraft 24 primer and top coat ov ...
Hen Bob Member
I do it with Clawlock all the time, sand to 150 and prime
