Spray booth size
10/31/16
chuck crawford
I've been using a homemade hillbilly exhaust fan that I shut an overhead door on for years. It actually works great as long as I open another door for some make up air.
My insurance company didnt care for it so now I'm in the market for an open face UL listed booth.
My question is what size booth to get. I build cabinets as long as 8' sometimes and finish molding at 12-14'. Do you need to always have what you're spraying totally inside the booth or will it work if its sitting just outside the front when I have the occasional larger piece?
I've read a rule of thumb is take the largest piece you will finish and add 3' on each end and 3' in depth but I don't want to give up space for a 20' wide booth if I don't have to.
Thanks for any advice.
10/31/16       #2: Spray booth size ...
herb johonson
instead of going wide go long like a 18ft long booth instead of 18ft wide
good luck
herb j
btw, get a variable speed fan motor
10/31/16       #3: Spray booth size ...
Since you insurance company is involved with the request for a change, make sure you run the plans by them before you purchase! They'll tell you how far the switches must be located from the booth, and other details. Also the orientation of the booth will effect the amount of filters you have to maintain. Yup, variable speed and booth coating before you use it.
10/31/16       #4: Spray booth size ...
chuck crawford
Herb, so you're saying go more depth, as in 18' from the open front to the filter wall? What would be a good width, 8' or so?
I can definitely see where that would be less than 1/2 the amount of filters.
Thanks for the tip on the variable speed fan.
11/1/16       #5: Spray booth size ...
Shane
yes get it wired up with a variable frequency drive... it will be your best tool for a spray booth
11/2/16       #6: Spray booth size ...
Jim
Not sure where you are located. I am selling a used southern California legal enclosed booth with dry chemical fire suppresion (sprinklers not needed) Las Vegas 1/4 of new price.....made in USA
.Jim
11/17/16       #8: Spray booth size ...
Most open faced booths in cabinet shops are designed for a cfm of the square footage of the open face. It really doesn't matter how much of your work piece is in or out of the booth. All the air is being drawn out of the room that the booth is in.
