SW Pre-cat
12/12/16
tom Member
Got 5 gallon of ( Hi-Bild T77 F57 ) from SW back in July
It expired 11/5/2016
The question i have is it still ok to use?
12/12/16       #2: SW Pre-cat ...
Shane
you should be fine..... put it on the shaker and spray a test board to make sure it cures... then do a scratch adhesion test to make sure it doesn't peel right up.... I've sprayed the same product much older than that when a bucket doesn't get rotated correctly....It has a very distinct smell when the paint has "turned" if you've ever got a whiff of precat getting bad...
