Bleaching Walnut
12/15/16
Hawke Member
I'm having some issues with a bleached Walnut project. I'm using the Woodkote 2 part bleach. Some of the boards are getting pink streaks. Any suggestions..?
12/15/16       #2: Bleaching Walnut ...
John S  Member
Instead of bleaching true Walnut, why not use Butternut (White Walnut)?
12/15/16       #3: Bleaching Walnut ...
Robert Member
Hawke...how old is the Woodkote ? Are the areas where the pink streaks are showing up, showing up on the sapwood? Are you using equal parts of A&B ? Are you applying it wet or really soaking it ? How are you applying it ?
Ive had great results with Woodkote ( used to be called Speed-E-Way ) while bleaching Walnut but it takes a few coats with complete drying in between coats.
If your finding that your raising the grain, you might be applying it to wet.
12/22/16       #4: Bleaching Walnut ...
Dustin Member
Something you might try is to make your own bleach so you can adjust the quantities of each part. You can buy everything needed on Amazon i.e.; 27% Hydrogen Peroxide and Sodium Hydroxide. The Blend that I have found to work on oak is 190 grams of SH to a gallon of water, then that mixed gallon to a gallon of Hydrogen Peroxide. However, you may want to tone down the SH. Maybe try 100 grams.
Often times wood bleach requires multiple coats, so this also might help.
