blotchy maple/washcoat
1/12/17
Ryan Groff
I have tried a few methods with maple and this issue, I think I'm going to try a wash coat next, I've read quite a bit on here about it I have two questions,
1) can I use a solvent base stain with a thinned down wash coat of clear stain base, vinyl sealer or lacquer, or will it dissolve it? or do i need to switch to a oil based stain?
Or does it depend on the solids content of the wash coat ?
2)If the wash coat lightens the stain and I am matching a sample do you adjust the stain darker to compensate? I am having sherwinn williams chemical coatings match all my stain, so do I give them a board with the wash coat on it to match the stain under the circumstances it will be applied. I assume so? Definetly need some advice here , so frustrated with this whole thing and these blotchy woods in general.
1/12/17       #2: blotchy maple/washcoat ...
Shane
Ton of different ways to go about it.... If you wash coat with lets say Sherwin vinyl sealer t67f7 5:1 ratio 5 parts reducer to 1 part sealer. It will in facts help with the blotch on maple if you wash coat give it a very light scuff then wipe your stain. problem is if your dealing with rich or dark colors it's not going to take much stain... try this. take your 4 0z. of your wiping stain and strain it through a fine cone strainer into a cup gun and fill the cup with naptha.. adjust the gun to just where the pencil point shape want to start the fan shape.... now get a little distance off the panel and spray evenly across the length while overlapping each stroke. you want to see the stain hit the surface and wet the stroke but your eyes will also see that wick in and the tail of the stroke flashing off... if you make several passes correctly you can build your color up to where you want it to match other panels beside it.... or use NGR colors reduced with acetone but that is a whole other ballgame mixing dyes to a desired match... We use reduced ngr to shift colors to match our final sample and sometimes strictly ngr... just depends.... try spraying your stain... just enough to pop the grain and it comes out a ton better than a wipe ever will...
1/12/17       #3: blotchy maple/washcoat ...
JM
As Shane mentions, take your stain, cut it with 3 or 4 parts naphtha to 1 part stain. Spray a wet coat on, dont wipe, let it dry, then topcoat.
No washcoat required and its a lot easier than wiping.
